| Type | SG-1C-111: SG-1C-121:
| Image sensor | |
| Day and Night | Mechanical IR filter |
| Minimum intensity of illumination | |
| Dynamic range | SG-1C-111: up to 120 dB SG-1C-121: up to 100 dB SG-1C-131: up to 76 dB SG-3C-1312: up to 76 dB |
| Video streams | Two streams (H.264, MPEG-4, MJPEG) through RTSP (unicast/multicast), MJPEG through HTTP, adjustable frame rate and channel bandwidth. |
| Frame size and compression |
SG-1C-131: |
| Image adjustment options | Brightness, contrast, sharpness, automatic white balance, automatic exposure, day & night mode, horizontal and vertical mirroring, on-screen display for arbitrary text, date, time, histogram |
| Audio stream | Bi-directional |
| Audio codecs | G.711 (8 KHz, 64 Kbit/s), AAC LC (8 KHz, adjustable bitrate) |
| Input and Output | Microphone input and line output |
| Control | Web interface for user/admin, SSH |
| Security | Access to Web interface is protected with a password; SSL (HTTPS) encryption; access through SSH protocol |
| Protocols | IPv4, HTTP, HTTPS, SSL, TLS, SSH, DHCP, NTP, RTSP, RTP, UDP, TCP, ARP |
| Programming interfaces | |
| Alert | Activation of external alert signals; video- and audio-recording to Micro SD card, alert warning through E-mail (SMTP) (in development), uploading file to FTP server, HTTP server. |
| Alert input/output | 2 inputs, 1 output, 1 line audio-output 3.5 mm |
| Detection | Motion detector |
| Control ports | RS-232 / RS-485 (selectable) for managing weather-proof IPhouse-15E/* housing modes |
| Local data storage | Slot for Micro SD cards |
| Processor and Memory | Texas Instruments TMS320DM368 432 MHz, 128 MB DDR2 SDRAM, 128 MB NAND flash |
| Camera box | Cast of aluminum alloy |
| Lens mounting type | CS |
| External dimensions (LxWxH), mm | 120 x 65 x 50 |
| Weight, g | 150 |
| Operating conditions | -50 .. +50 C with a weather-proof housing IPhouse-15E/* and -35 .. +50 C without weather-proof housings |
| Network interface | 2 x Ethernet 10/100 |
| Power supply | Local 12V or PoE class 2 with a feature of through-line powering of several cameras |
| Power consumption, W | 4.5 |
