Video surveillance systems
Usage examples in this and branch groups:
Linking a group of Sigrand IP-cameras featuring SHDSL interfaces to the network over sigrand DSLAM
Purpose: linking a group of Sigrand IP-cameras to information line over great distances via SHDSL interfaces.The cameras are linked to SHDSL modular interfaces of Sigrand SG-17AM DSLAM. From 4 to 16 SHDSL ports may be installed on a DSLAM tub. Transfer rate in the line reaches 15296 kbit/s over single pair. The SG-17R DSLAM is linked ot information line over gigabit copper or optical Ethernet interface. Traffic management is carried out by menas of VLAN technology. The cameras are powered locally or remotely from the SG-17R module.
IPcam-1,2/DM368/MT9M034/D, IPcam-3,1/DM368/AR0331/D, ( Базовая платформа SG-17S-1RU-CP1-2ETH/220VAC-W3, Базовая платформа SG-17S-1RU-CP1-2ETH/DC ), ( Модуль MS-17H4, Модуль MS-17H4P2 )
Linking a group of IP-cameras to the network over Sigrand commutator
Purpose: linking a group of arbitrary IP-cameras to information line via Ethernet interfaces. The cameras are linked to modular Ethernet interfaces of Sigrand SG-17AM DSLAM. From 4 to 16 Ethernet ports featuring PoE technology may be installed on one DSLAM tub. The SG-17AM DSLAM is linked to information line over gigabit copper or optical Ethernet interface. Traffic management is carried out by means of VLAN. The cameras are powered remotely from Ethernet module, installed on SG-17AM.
IPcam-1,2/DM368/MT9M034/E, IPcam-3,1/DM368/AR0331/E, ( Базовая платформа SG-17S-1RU-CP1-2ETH/220VAC-W3, Базовая платформа SG-17S-1RU-CP1-2ETH/DC ), ( Модуль MS-17E8, Модуль MS-17E8P )
Linking a group of IP-cameras featuring Ethernet and SHDSL interfaces to the network over Sigrand commutator
Purpose: linking various IP-cameras to information line over different interfaces. The cameras are linked to the Ethernet PoE and SHDSL PoDSL modular interfaces of the SG-17AM Sigrand DSLAM. Up to 4 modules in different combinations may be installed on a single DSLAM tub. The SG-17R DSLAM tub is linked to information line over gigabit or optical Ethernet interface. Traffic management is carried out by means of VLAN. One arbitrary IP-camera and one SIgrand IP-camera Ipcam-20PE/Ipcam-04PEN are linked via Ethernet interfaces. Remote IP-camera Sigrand Ipcam-20PD/Ipcam-04PDN is linked via SG-17R SHDSL module. Remote arbitrary IP-camera is linked via SG-17BT SHDSL modem, which transits remote power for further linking using PoE.
SHDSL модем SG-17B-P/T-M, SG-17BT SHDSL modem, ( IPcam-1,2/DM368/MT9M034/D, IPcam-1,2/DM368/MT9M034/E, IPcam-3,1/DM368/AR0331/D, IPcam-3,1/DM368/AR0331/E ), ( Базовая платформа SG-17S-1RU-CP1-2ETH/220VAC-W3, Базовая платформа SG-17S-1RU-CP1-2ETH/DC ), ( Модуль MS-17E8, Модуль MS-17E8P ), ( Модуль MS-17H4, Модуль MS-17H4P2 )
Linking a group of local and remote IP-cameras to the network over commutator
Purpose: linking different IP-cameras to information network over different interfaces. The cameras are linked to a standard PoE-featuring Ethernet commutator. The remote Ipcam-20PD/Ipcam-04PDN Sigrand IP-camera is linked over SG-17B SHDSL modem. Remote arbitrary IP-camera is linked over two SG-17B SHDSL modems. Transfer rate on the line for remote link-up reaches 15296 kbit/s over single pair. Local arbitrary IP-camera is linked to the commutator over PoE.
SG-17B SHDSL modem, SHDSL модем SG-17B-12-M, SHDSL модем SG-17B-3.3-M, SHDSL модем SG-17B-48-M, ( IPcam-1,2/DM368/MT9M034/D, IPcam-1,2/DM368/MT9M034/E, IPcam-3,1/DM368/AR0331/D, IPcam-3,1/DM368/AR0331/E )
Branched linking of IP-cameras using Sigrand equipment
Purpose: linking distributed IP cameras to the information line over different interfaces. Special T-shaped SHDSL regenerators are used to establish video surveillance networks along trunk systems. These regenerators help to receive remote power supply from the SHDSL module installed on SG-17R. The regenerators function as offsets for further linking of SG-17AM DSLAMs, routers or SG-17R-based bridges. The regenerator may be set off over Ethernet or SHDSL interfaces. An arbitrary remote IP-camera is linked upp through SG-17BT SHDSL modem, which completes the remote power transition for PoE-based connection. The transfer rate on the remote-connection line reaches 15296 kbit/s over single pair. A group of Sigrand IP-cameras is linked up over Sigrand DSLAM using SHDSL or Ethernet connections. Several DSLAMs may be installed along single trunk. Each DSLAM allows up to 16 IP-cameras. Locally powered SG-17R routers may be used instead of regenerators. The SG-17AM DSLAM is linked to information line over copper gigabit or optical Ethernet interface. SG-17R router, if used instead of DSLAM, through additional modules may feature telephones, PBXs, sensors, controllers, WiFi devices.
SG-17E2P-SLG, SG-17EP-SLG, SHDSL модем SG-17B-P/T-M, SG-17BT SHDSL modem, ( IPcam-1,2/DM368/MT9M034/D, IPcam-1,2/DM368/MT9M034/E, IPcam-3,1/DM368/AR0331/D, IPcam-3,1/DM368/AR0331/E ), ( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform ), ( Базовая платформа SG-17S-1RU-CP1-2ETH/220VAC-W3, Базовая платформа SG-17S-1RU-CP1-2ETH/DC ), ( Module MR-17H1, Module MR-17H1P2, Module MR-17H2, Module MR-17H2P2 ), ( Модуль MS-17H4, Модуль MS-17H4P2 )
Linking remote Sigrand IP-cameras to the network over SHDSL
Purpose: linking the Sigrand IPcam-20PD/IPcam-04PDN IP-camera to the information line over great distance through SHDSL interface. The camera is linked to the SHDSL interface of the SG-17B modem. Transfer rate on the line reaches 15296 kbit/s over single pair. The camera is powered locally.
IPcam-1,2/DM368/MT9M034/D, IPcam-3,1/DM368/AR0331/D, SG-17B SHDSL modem, SHDSL модем SG-17B-12-M, SHDSL модем SG-17B-3.3-M, SHDSL модем SG-17B-48-M
Linking remote Sigrand IP-camera featuring remote power supply over PoDSL through SHDSL link using regenerator
Purpose: linking Sigrand IPcam-20PD/IPcam-04PDN IP-cameras to the information line over great distances through SHDSL interface using regenerator. The camera is linked to the SHDSL interface of the SG-17EP regenerator. Transfer rate in the line reaches 15296 kbit/s over single pair. The camera is powered remotely from SG-17R SHDSL module. Up to 3 regenerators powered on one side may be installed on single line.
IPcam-1,2/DM368/MT9M034/D, IPcam-3,1/DM368/AR0331/D, SG-17EP-SLG, Module MR-17H1P2, Module MR-17H2P2, ( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform )
Linking remote arbitrary IP-camera with PoE-assisted remote power supply over SHDSL
Purpose: linking remote Ethernet interface-featuring devices that require remote power supply, e.g. IP-cameras, IP-telephones. The equipment system includes SG-17BT modem and SG-17AM or SG-17R modular Sigrand DSLAM. Transfer rate over single pair reaches 15296 kbit/s. The SG-17BT modem installed in camera case receives remote power from the line from SHDSL modules installed on the SG-17AM/SG-17R DSLAM. The modem ensures further transit of this power to the Ethernet port, to which a camera that supports class 2 PoE may be linked.
IPcam-1,2/DM368/MT9M034/E, IPcam-3,1/DM368/AR0331/E, SHDSL модем SG-17B-P/T-M, Module MR-17H1P2, Module MR-17H2P2, Модуль MS-17H4P2, ( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform ), ( Базовая платформа SG-17S-1RU-CP1-2ETH/220VAC-W3, Базовая платформа SG-17S-1RU-CP1-2ETH/DC )
Linking remote arbitrary IP-camera with PoE-assisted remote power supply over SHDSL using regenerator
Purpose: linking remote Ethernet interface-featuring devices that require remote power supply, e.g. IP-cameras, IP-telephones. The equipment system includes SG-17BT modem and SG-17AM or SG-17R modular Sigrand DSLAM. Transfer rate over one pair reaches 14080 bit/s. The link-up is completed through intermediate regenerator. The SG-17BT modem installed in the camera case receives remote power from the line from SG-17EP regenerator. The modem ensures further transit of this power to the Ethernet port, to which a camera that supports class 2  PoE may be linked. The regenerator receives remote power form the line supplied by SHDSL modules installed on SG-17R or SG-17AM DSLAM.
IPcam-1,2/DM368/MT9M034/E, IPcam-3,1/DM368/AR0331/E, SG-17EP-SLG, SHDSL модем SG-17B-P/T-M, Module MR-17H1P2, Module MR-17H2P2, Модуль MS-17H4P2, ( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform ), ( Базовая платформа SG-17S-1RU-CP1-2ETH/220VAC-W3, Базовая платформа SG-17S-1RU-CP1-2ETH/DC )
1 - 10 11 - 20
