Module MR-17Vs8 (8xFXS)
(CONFIGURATION EXAMPLE)
Module MR-17Vs8 (8xFXS) is a typical example of modular configuration. Module is designed for setting up analog interface for further linking to %%функциональность модуля%%. Module MR-17Vs8 (8xFXS) features %%количество интерфейсов%%; it includes one %%MR-17V%% module and %%число%% %%субмодуль%%.
Usage example description Purpose: setting up VoIP gateways with different functional FXO and FXS modules. From 2 to 32 single-type ports in increments of 2 may be installed simultaneously. Simultaneous operation of the FXO (MR-17V8/SMR-17Vo) and FXS (MR-17V8/SMR-17Vs) modules is possible, the modules possessing the functions of a mini-BPX. Any interfaces of SG-17R (Ethernet, SHDSL, E1) may operate as channel-forming equipment.
Using in usage example products and product groups Module MR-17G1,
Module MR-17V4,
Submodule SMR-17VF,
Submodule SMR-17VO,
Submodule SMR-17VS
Using in usage example products and product groups SHDSL модем SG-17B-3.3-M,
Module MR-17V8,
Submodule SMR-17VO,
Submodule SMR-17VS,
Usage example description Purpose: simultaneous transfer of voice frequency channels and other services, e.g. Ethernet or VoIP-based telephony. VF channels may be transmitted with a fixed band being isolated in the global traffic that is transmitted through existing city infrastructure, e.g. SDH network.
Module MR-17V4,
Submodule SMR-17VF,
Submodule SMR-17VO,
Submodule SMR-17VS
Products:
(1 pc.)
Submodule SMR-17VS
(4 pcs.)
Module MR-17Vs8 (8xFXS) with eight FXS channels holds the “ Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2569.
years
