Module MR-17Vo8 (8xFXO) is a typical example of modular configuration. Module is designed for setting up analog interface for further linking to %%функциональность модуля%%. Module MR-17Vo8 (8xFXO) features %%количество интерфейсов%%; it includes one %%MR-17V%% module and %%число%% %%субмодуль%%.
Module MR-17G1,
Module MR-17V4,
Submodule SMR-17VF,
Submodule SMR-17VO,
Submodule SMR-17VS
Module MR-17V8,
Submodule SMR-17VO,
Submodule SMR-17VS,
Module MR-17G1,
Module MR-17V4,
Submodule SMR-17VF,
Submodule SMR-17VO,
Submodule SMR-17VS
Products:
(1 pc.)
Submodule SMR-17VO
(4 pcs.)
Module MR-17Vo8 (8xFXO) with 8 FXO channels holds the “Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2566.
years
