Module MR-17Vo2 (2xFXO)
(CONFIGURATION EXAMPLE)
Module MR-17Vo2 (2xFXO) is a typical example of modular configuration. Module is designed for setting up analog interface for further linking to %%функциональность модуля%%. Module MR-17Vo2 (2xFXO) features %%количество интерфейсов%%; it includes one %%MR-17V%% module and %%число%% %%субмодуль%%.
Module MR-17Vo2 (2xFXO) may be extended to its maximum capacity with SMR-17VS(FXS), SMR-17VO(FXO), SMR-17VF(VF) submodules. Maximum capacity is four interfaces (MR-17V4 used) or eight interfaces (MR-17V8 used). Submodules may be used in any combination
Usage example description Purpose: setting up VoIP gateways with different functional FXO and FXS modules. From 2 to 32 single-type ports in increments of 2 may be installed simultaneously. Simultaneous operation of the FXO (MR-17V8/SMR-17Vo) and FXS (MR-17V8/SMR-17Vs) modules is possible, the modules possessing the functions of a mini-BPX. Any interfaces of SG-17R (Ethernet, SHDSL, E1) may operate as channel-forming equipment.
Using in usage example products and product groups Module MR-17G1,
Module MR-17V4,
Submodule SMR-17VF,
Submodule SMR-17VO,
Submodule SMR-17VS
Usage example description Purpose: simultaneous transfer of voice frequency channels and other services, e.g. Ethernet or VoIP-based telephony. VF channels may be transmitted with a fixed band being isolated in the global traffic that is transmitted through existing city infrastructure, e.g. SDH network.
Module MR-17V4,
Submodule SMR-17VF,
Submodule SMR-17VO,
Submodule SMR-17VS
Usage example description Purpose: providing “All-over-IP” multiple services by linking the IP-camera to SG-17R base platform, which operates in the router mode. High transfer rates on SHDSL and various interfaces on the router let almost any services be transmitted over single pair in various combinations. SG-17R used, the object will be provided with video surveillance, telephony, local network; the object will furthermore feature controllers, sensors, VF channels, digital PBXs, Wi-Fi devices. In common network a router may be linked up over almost any channel-forming equipment, running within SG-17R.
Using in usage example products and product groups Module MR-17H1,
Module MR-17G1,
Module MR-17G2,
Module MR-17G4,
Module MR-17S2C,
Module MR-17S2T,
Module MR-17S4C,
Module MR-17V4,
Submodule SMR-17VF,
Submodule SMR-17VO,
Submodule SMR-17VS
Products:
Submodule SMR-17VO
(1 pc.)
Product groups
(any of product of the product group can be used):
Submodule SMR-17VF
Submodule SMR-17VO
Submodule SMR-17VS
Module MR-17Vo2 (2xFXO) with two FXO channels holds the “Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2564.
years
