| SG-17R-1RU-CP1-4ETH/220VAC-W1 base platformProduct designationModular base platform 220 V AC powerSections:Technical characteristics
DescriptionFunctions The SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform modular platform is designed to operate as a router, multiplexer, bridge, DSLAM, access server, IP-gateway, IT-PBX, most of the functions being carried out simultaneously by the same device.
IP-PBX The IP-PBX mode allows setting up miniPBX, which, in its turn enables calls over SIP-server, calls between ports within single device or among different SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform devices. The miniPBX enables automatic call-forwarding between FXS/FXO ports. Software: The software of the SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform platform is Linux OS freeware. The platform is controlled through web-interface (Russian and English); troubleshooting is completed over serial port or over SSH protocol. The platform software is updated via TFTP server. Data transmission SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform supports “bonding” mechanism or PPP-Multilink protocol both of which enable uniting SHDSL, E1, RS232 interfaces for further increasing the carrying capacity and improving reliability. When using “bonding”, the channel capacity remains unchanged irrespective of integrity of the pairs, over which data is transmitted. Furthermore, transmission rate may be set taking into account the maximum carrying capacity of the channels. SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform may operate as firewall, rejecting or accessing packets on the basis of the protocol, source and destination addresses and No. of the ports used. By means of NAT address translation applicable to SNAT or DNAT is completed. QoS enables prioritizing packets. QoS is supported by various class and classless disciplines. There is an option of singling out fixed bands for different types of traffic or for different networks. VLAN support helps to isolate traffic transmitted through the same physical medium. The port may be set up so as to transmit either entire traffic or single packets with certain LAN numbers. SG-17R enables crating tunnels for tamper-free data exchange. Hardware Built-in Ethernet ports may be set up as commutators, i.e. may transmit data by-passing the processer. These ports operate as a single network interface in the system. Interdependence of the interfaces may be set, in which case, for instance, if the link on SHDSL fails, the link of the corresponding Ethernet or E1 interface turns down as well. Services SG-17R features built-in DHCP and DNS servers. DHCP server allows assigning IP addresses to PCs in the networks it runs in. DNS server helps transfer requests to higher-level DNS-servers or locate DNS zones directly on the device. Monitoring SG-17R enables receiving multiple parameters of SHDSL channel (signal to noise ratio, number of errors, etc) through separate EOC control channel. This information is available via web-interface or via SNMP (HDSL2-SHDSL-LINE-MIB). Basic information on the system in accordance with MIB-2 is also available via SNMP: information about network interfaces, routing tables, processor load, etc. Generation of NetFlow (v.1, 5, 7) may be set up for collection of statistic on the volume of traffic.
Usage examplesUniting Ethernet networks over several pairs using different interfaces: SHDSL, E1, RS232Usage example description Purpose: uniting two Ethernet networks to reach full output in the link by using the bonding mode. In this scheme SG-17R provides either internetwork connection between two Ethernet groups with routing rules or bridge link with shared addressing of the networks united. Transfer rate over each pair reaches 14080 kbit/s. Different transfer rate may be set up in different pairs. It is important that even if on one of the pairs there is a link loss, the performance of the channel does not fail. Up to 6 pairs may be simultaneously linked to a single SG-17R device for SHDSL links based on SG-17R-1RU-CP1-4ETH platform. Up to 8 pairs may be simultaneously linked to a single SG-17R device for SHDSL links based on SG-17R-1RU-CP2-3SFP platform. Besides, in the bonding mode it is possible to unite any kind of channel-forming equipment, through which IP-traffic is transferred: E1, RS-232. Both Ether-HDLC and PPP-multilink may be chosen as protocols. Using in usage example products and product groups (
Module MR-17G1,
Module MR-17G2,
Module MR-17G4,
Module MR-17H1P2,
Module MR-17H2,
Module MR-17S2C,
Module MR-17S2T,
Module MR-17S4C,
Uniting Ethernet networks using SHDSL with VLAN-assisted traffic isolationUsage example description Purpose: splitting the users’ traffic in the shared physical medium of data transfer. The SG-17R device supporting VLAN technology allows uniting LAN 1 and LAN 2 networks independently. Up to 4 Ethernet networks may be simultaneously linked to a single SG-17R. Each Ethernet port may be set up so as to transfer either the whole traffic or single packets with a certain VLAN number. Transfer rate over each pair reaches 14080 kbit/s. Up to 6 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP1-4ETH platform. Up to 8 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP2-3SFP platform. Using in usage example products and product groups (
Module MR-17H1P2,
Module MR-17H2,
Uniting Ethernet networks using SHDSL with remote power supplyUsage example description Purpose: linking remote points (single computers or local Ethernet networks) over bridge link with shared addressing mode. Transfer rate over single pair reaches 15296 kbit/s. SG-17B allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces. The SG-17BP modem receives remote power from the line from SHDSL modules, installed on SG-17R or SG-17AM DSLAM. Using in usage example products and product groups SHDSL модем SG-17B-P-M,
SG-17BP SHDSL modem,
Module MR-17H1P2,
Module MR-17H2P2,
View all usage examplesSupported productsIn this product the following products can be used:
Module MR-17G1
Module MR-17G2
Module MR-17G4
Module MR-17H1
Module MR-17H1P2
Module MR-17H2
Module MR-17S2C
Module MR-17S2T
Module MR-17S4C
Module MR-17V4
Module MR-17Vo2 (2xFXO)
Module MR-17Vo4 (4xFXO)
Module MR-17Vo8 (8xFXO)
Module MR-17Vs2 (2xFXS)
Module MR-17Vs4 (4xFXS)
Module MR-17Vs8 (8xFXS)
Typical example of VoIP modular assembly CertificatesThe SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform base platform holds "Declaration of conformity", issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2554. Price and warrantyWarranty5 yearsPrice
