Linking subscribers and networks to central access point using SHDSL
Usage example description Purpose: linking remote points (single computers or local Ethernet networks) to the central network over bridge link with shared addressing mode or over internetwork connection with routing rules. Transfer rate over each pair reaches 14080 kbit/s. Up to 6 clients may be linked to a single SG-17R device based on the SG-17R-1RU-CP1-4ETH platform. Up to 8 clients may be linked to a single SG-17R device based on the SG-17R-1RU-CP2-3SFP platform. Up to 16 clients may be linked to a single SG-17R device in DSLAM mode. In order to link super-remote clients it is possible to use additional SG-17E regenerators with local or remote power supply. The line is powered over MR-17H*P SHDSL module. SG-17B or SG-17BP compact size modem may be used as a remote modem, having an option to receive remote power supply from information line.
Using in usage example products and product groups SG-17B SHDSL modem,
SHDSL модем SG-17B-P-M,
SG-17BP SHDSL modem,
Module MR-17H1P2,
Module MR-17H2,
