Module MR-17Vs8 (8xFXS)
Module MR-17Vs8 (8xFXS) (CONFIGURATION EXAMPLE)
 Module MR-17Vs8 (8xFXS) is a typical example of modular configuration. Module is designed for setting up analog interface for further linking to %%функциональность модуля%%. Module MR-17Vs8 (8xFXS) features %%количество интерфейсов%%; it includes one %%MR-17V%% module and %%число%% %%субмодуль%%.
SHDSL модем SG-17B-3.3-M, Module MR-17V8, Модуль MS-17E8P, Модуль MS-17H4, Модуль MS-17H4P2, Submodule SMR-17VO, Submodule SMR-17VS, ( Базовая платформа SG-17S-1RU-CP1-2ETH/220VAC-W3, Базовая платформа SG-17S-1RU-CP1-2ETH/DC )
Products:
Module MR-17V8 (1 pc.)
Submodule SMR-17VS (4 pcs.)
Module MR-17Vs8 (8xFXS) with eight FXS channels holds the “Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2569.
