Data transmission systems
Usage examples in this and branch groups:
Purpose: splitting the users’ traffic in the shared physical medium of data transfer. The SG-17R device supporting VLAN technology allows uniting LAN 1 and LAN 2 networks independently. Up to 4 Ethernet networks may be simultaneously linked to a single SG-17R. Each Ethernet port may be set up so as to transfer either the whole traffic or single packets with a certain VLAN number. Transfer rate over each pair reaches 14080 kbit/s. Up to 6 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP1-4ETH platform. Up to 8 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP2-3SFP platform.
( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform ), ( Module MR-17H1, Module MR-17H1P2, Module MR-17H2, Module MR-17H2P2 )
Purpose: linking remote points (single computers or local Ethernet networks) over bridge link with shared addressing mode. Transfer rate over single pair reaches 15296 kbit/s. SG-17B allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces. The SG-17BP modem receives remote power from the line from SHDSL modules, installed on SG-17R or SG-17AM DSLAM.
SHDSL модем SG-17B-P-M, SG-17BP SHDSL modem, Module MR-17H1P2, Module MR-17H2P2, ( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform )
Uniting Ethernet networks using SHDSL with remote power supply over additional regenerator
Purpose: linking remote points (single computers or local Ethernet networks) over bridge link with shared addressing mode. The link-up is completed through intermediate regenerator. Transfer rate reaches 14080 kbit/s over single pair. The SG-17BP modem allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces. The SG-17BP modem receives remote power from SG-17EP regenerator. The regenerator receives remote power from the line from SHDSL modules installed on 17R or SG-17AM DSLAM.
SG-17E2P-SLG, SG-17EP-SLG, SHDSL модем SG-17B-P-M, SG-17BP SHDSL modem, Module MR-17H1P2, Module MR-17H2P2, ( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform )
Uniting Ethernet networks using SHDSL, up to 15.2 Mbit/s over single pair
Purpose: uniting remote points (single computers or local Ethernet networks) over bridge link with shared addressing. Transfer rate over single pair reaches 15296 kbit/s. SG-17B allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces.
SG-17B SHDSL modem, SHDSL модем SG-17B-12-M, SHDSL модем SG-17B-3.3-M, SHDSL модем SG-17B-48-M
Uniting Ethernet networks over E1 channel using SDH/PDH transport systems
Purpose: uniting Ethernet networks through existing networks, built using E1 equipment. In order to increase the carrying capacity of SG-17R several E1/G.703 interfaces may be linked to the device. Single E1 module (MR-17G*) may feature up to 8 ports.
Module MR-17G1, ( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform )
 Purpose: splitting the users’ traffic in the shared physical medium of data transfer. The SG-17R device supporting VLAN technology allows uniting LAN 1 and LAN 2 networks independently. Up to 4 Ethernet networks may be simultaneously linked to a single SG-17R. Each Ethernet port may be set up so as to transfer either the whole traffic or single packets with a certain VLAN number. Single E1 module (MR-17G*) may feature up to 8 ports. Single SG-17R device may feature up to 32 E1 channels.
Uniting Ethernet networks over several E1 channels using SDH/PDH transport systems
Purpose: uniting Ethernet networks through existing networks, built using E1 equipment. In order to increase the carrying capacity of SG-17R several E1/G.703 interfaces may be linked to the device. Single E1 module (MR-17G*) may feature up to 8 ports. Up to 32 E1 channels may be simultaneously linked to single SG-17R.
Uniting networks for "E1 + Ethernet" transmission over several pairs using SHDSL
Purpose: simultaneous IP and TDM transfer of mixed traffic over DSL links. As the transfer rate over single pair may reach 14080 kbit/s, up to 6 E1/G.703 ports may be linked to a single SG-17R for single-pair transfer. Up to 3 E1 modules may be installed, only one DSL module used.  One E1 module (MR-17G*) may feature up to 8 ports. Single SG-17R device may feature up to 6 pairs. There is an option to aggregate the surplus of the Ethernet bands from different pairs into a single logical channel. Another option is to arrange traffic isolation among networks by means of VLAN.
Uniting networks for "E1 + Ethernet" transmission over single pair using SHDSL
Purpose: simultaneous IP and TDM transfer of mixed traffic over DSL links. As the transfer rate over single pair may reach 14080 kbit/s, up to 6 E1 ports may be linked to SG-17R for single-pair transfer. Single E1 module (MR-17G*) may feature up to 8 ports. Up to 6 pairs may be simultaneously linked to a single SG-17R.
Module MR-17G1, Module MR-17H1, ( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform )
1 - 10 11 - 20 21 - 30 31 - 40
