SG-17R/MR-17V/2*SMR-17Vs/MR-17G1 (4xFXS, 1xE1, 4xETH 10/100) (CONFIGURATION EXAMPLE)
Typical assemby of 2-channel VoIP gateway with FXO, FXS and voice frequency channels featuring additional E1 interface.
Module MR-17G1
Module MR-17G2
Module MR-17G4
Module MR-17H1
Module MR-17H1P2
Module MR-17H2
Module MR-17S2C
Module MR-17S2T
Module MR-17S4C
Module MR-17V4
Module MR-17Vo8 (8xFXO)
Module MR-17Vs8 (8xFXS)
Submodule SMR-17VF
Submodule SMR-17VO
Submodule SMR-17VS
The SG-17R base platform holds "Declaration of conformity" issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2554.
The MR-17Vs4 module with 4 FXS channels holds "Declaration of conformity" issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2568.
The MR-17Vo4 module with 4 FXO channels holds "Declaration of conformity" issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2565.
The MR-17G1 module holds "Declaration of conformity" issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2556.
1 order
1 order
1 order
2 order
Total order
