SHDSL модем SG-17B-48-M
Rate table
Rate, kbit/s | 0.5 mm cable, km | 0.9 mm cable, km (*) | 1.2 mm cable, km (*) | 15296 | 0,6 | | | 14080 | 1,0 | 3,6 | 5,8 | 12800 | 1,2 | 3,8 | 6,4 | 11520 | 1,4 | 4,2 | 6,4 | 10240 | 2,0 | 4,6 | 7,2 | 9216 | 2,2 | 4,8 | 7,4 | 8192 | 2,4 | 5,0 | 8,0 | 7168 | 3,0 | 5,4 | 8,4 | 6144 | 3,4 | 6,0 | 9,0 | 5696 | 3,6 | 6,8 | 10,6 | 5120 | 3,8 | 7,2 | 12,0 | 4608 | 4,0 | 7,4 | 13,0 | 4096 | 4,4 | 8,0 | 14,0 | 3072 | 5,0 | 9,0 | 15,8 | 2304 | 5,4 | 10,6 | 17,0 | 2048 | 6,2 | 12,6 | 19,4 | 1536 | 7,0 | 14,8 | 22,2 | 1024 | 7,8 | 17,0 | 26,0 | 768 | 8,4 | 18,4 | 28,0 | 512 | 9,0 | 19,8 | 30,0 | 384 | 9,6 | 21,2 | 32,0 | 192 | 10,4 | 23,0 | 35,0 | | (*) - not all data obtained expermentally. |
Linking a group of local and remote IP-cameras to the network over commutator
Usage example description Purpose: linking different IP-cameras to information network over different interfaces. The cameras are linked to a standard PoE-featuring Ethernet commutator. The remote Ipcam-20PD/Ipcam-04PDN Sigrand IP-camera is linked over SG-17B SHDSL modem. Remote arbitrary IP-camera is linked over two SG-17B SHDSL modems. Transfer rate on the line for remote link-up reaches 15296 kbit/s over single pair. Local arbitrary IP-camera is linked to the commutator over PoE.
Using in usage example products and product groups SG-17B SHDSL modem,
Uniting Ethernet networks using SHDSL, up to 15.2 Mbit/s over single pair
Usage example description Purpose: uniting remote points (single computers or local Ethernet networks) over bridge link with shared addressing. Transfer rate over single pair reaches 15296 kbit/s. SG-17B allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces.
Linking users and networks to central access point for «Ethernet» and «E1 + Ethernet» mixed traffic transmission using SHDSL
Usage example description Purpose: setting up company-wide central access node to unite several remote Ethernet networks or single computers and connecting E1/G.703-featuring equipment. Several DSL interfaces of SG-17R may operate simultaneously in different modes, thus completing data multiplexing, data routing and acting as a firewall. Transfer rate over each pair reaches 14080 kbit/s. Up to 3 E1 modules may be installed, single DSL module used. The max capacity of one E1 module (MR-17G*) is 8 channels. Up to 6 DSL pairs may be simultaneously linked to a single SG-17R.
Module MR-17G1,
Module MR-17G2,
Module MR-17G4,
Module MR-17H1P2,
Module MR-17H2,
years
Product name |
Quantity (pc.) |
Price in USD |
Price in FOB USD:
Total |
order
