Usage example description Purpose: uniting two Ethernet networks to reach full output in the link by using the bonding mode. In this scheme SG-17R provides either internetwork connection between two Ethernet groups with routing rules or bridge link with shared addressing of the networks united. Transfer rate over each pair reaches 14080 kbit/s. Different transfer rate may be set up in different pairs. It is important that even if on one of the pairs there is a link loss, the performance of the channel does not fail. Up to 6 pairs may be simultaneously linked to a single SG-17R device for SHDSL links based on SG-17R-1RU-CP1-4ETH platform. Up to 8 pairs may be simultaneously linked to a single SG-17R device for SHDSL links based on SG-17R-1RU-CP2-3SFP platform. Besides, in the bonding mode it is possible to unite any kind of channel-forming equipment, through which IP-traffic is transferred: E1, RS-232. Both Ether-HDLC and PPP-multilink may be chosen as protocols.
Using in usage example products and product groups (
Module MR-17G1,
Module MR-17G2,
Module MR-17G4,
Module MR-17H1P2,
Module MR-17H2,
Module MR-17S2C,
Module MR-17S2T,
Module MR-17S4C,
Usage example description Purpose: splitting the users’ traffic in the shared physical medium of data transfer. The SG-17R device supporting VLAN technology allows uniting LAN 1 and LAN 2 networks independently. Up to 4 Ethernet networks may be simultaneously linked to a single SG-17R. Each Ethernet port may be set up so as to transfer either the whole traffic or single packets with a certain VLAN number. Transfer rate over each pair reaches 14080 kbit/s. Up to 6 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP1-4ETH platform. Up to 8 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP2-3SFP platform. Using in usage example products and product groups (
Module MR-17H1P2,
Module MR-17H2,
Usage example description Purpose: linking remote points (single computers or local Ethernet networks) over bridge link with shared addressing mode. Transfer rate over single pair reaches 15296 kbit/s. SG-17B allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces. The SG-17BP modem receives remote power from the line from SHDSL modules, installed on SG-17R or SG-17AM DSLAM.
Using in usage example products and product groups SHDSL модем SG-17B-P-M,
SG-17BP SHDSL modem,
Module MR-17H1P2,
Module MR-17H2P2,
Module MR-17G1
Module MR-17G2
Module MR-17G4
Module MR-17H1
Module MR-17H1P2
Module MR-17H1P2 is designed to be installed on the universal multiservice SG-17R platform as SHDSL channel-forming equipment
Module MR-17H1P2 provides remote power to regenerators, modems and IP-cameras over information line
Module MR-17H2
Module MR-17H2P2 is designed to be installed on the universal multiservice SG-17R platform as SHDSL channel-forming equipment
Module MR-17H2P2 provides remote power supply to regenerators, modems and IP-cameras over information line
Module MR-17S2C
Module MR-17S2T
Module MR-17S4C
Module MR-17V4
years
