SG-17EP-SLG is designed for increasing the distance between two SHDSL devices SG-17EP-SLG operates over one pair
  • G.SHDSL linear interface characteristics:
    • Number of interfaces: 1
    • Connection type: point-to-point
    • Number of wires in a line: 2 (one pair)
    • Transmission rate, kbit/s: 192-14080
    • Rate increment, kbit/s: 64
    • Linear code: TC-PAM
    • Communication type: full duplex
    • Input wave impedance, ohm: 135
    • Built-in overload protection
    • Compatibility: SHDSL MR-17H* and MR-17H*P modules installed on SG-17R tub, SG-17B* modem
  • Operation control:
    • From a remote device through SHDSL EOS
    • Statistics gathering by means of SNMP
    • An option of built-in software through RS232 port
  • Service traffic
    • Service traffic support: available
  • Power supply
    • Local: 36-72 VDC (optional)
    • Remote feed: 250 V, 60 mA (four regenerators in one half-section over single pair)
    • Power consumption: no more than 2,5 W (over single pair)
    • Operation mode: loop or transit of remote power supply
  • RS232C interface characteristics:
    • Protocol: 8-N-1
    • Stream control: not available
  • Additional functions:
    • Outside alarm interfaces: 3 pairs of contacts to link 3 external “dry contact” sensors
    • ’Copy-paste’ function of the channels: not available
  • Other characteristics
    • Silumin case IP-67
      • Height, mm: 55
      • Width, mm: 147
      • Depth, mm: 225
    • Weight, g: 600
    • Connectors: leakproof metal connectors, one for each group of signals
  • Service conditions:
    • Air temperature: -30 … +45 °С
    • Relative humidity:  up to 100%
    •  Air pressure: 84 – 107 kPa
Rate table
Rate, kbit/s0.5 mm cable, km0.9 mm cable, km (*)1.2 mm cable, km (*)
(*) - not all data obtained expermentally.
The regenerators are powered either locally or remotely over the information line from SHDSL modules installed on SG-17R tub. Up to 8 SG-17EP-SLG regenerators powered remotely may be installed on single communication line. The regenerators operate in the rate range 192 – 14080 kbit/s and enable the transfer of the complete set of multipurpose services without any quality losses. The SG-17EP-SLG regenerators belong to the class of unattended equipment. The regenerators are controlled through EOS service channel in the SHDSL link from the side of linear terminal equipment and do not need any additional user adjustments. Remote statistics gathering by means of SNMP allows checking and estimating the operation capacity of separate segments and of the point-to-point channel.  The construction of the regenerators is guarded. “Dry contact” control sensors and interphones may be linked to the regenerators. The information on condition of the sensors is available over EOS. This provides control over emergency situations (break-in, fire, flood) in the locations of the equipment.
Uniting networks using SHDSL with additional regenerators
It is possible to establish various systems along extended trunks regenerators using SG-17E regenerators. Up to 8 remotely-powered regenerators may be installed on single line. The remote power is supplied by MR-17H*P modules. In case of local power the number of regenerators in a line is not restricted.
SG-17E2P-SLG, SG-17EP-SLG, ( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform ), ( Module MR-17H1, Module MR-17H1P2, Module MR-17H2, Module MR-17H2P2 )
 The SG-17EP-SLG regenerator holds "Declaration of conformity" issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2555.
Total order
