 Module MR-17Vo4 (4xFXO)
Module MR-17Vo4 (4xFXO) (CONFIGURATION EXAMPLE)
  Module MR-17Vo4 (4xFXO) is a typical example of modular configuration. Module is designed for setting up analog interface for further linking to %%функциональность модуля%%. Module MR-17Vo4 (4xFXO) features %%количество интерфейсов%%; it includes one %%MR-17V%% module and %%число%% %%субмодуль%%.
Module MR-17Vo4 (4xFXO) may be extended to maximum capacity with SMR-17VS(FXS), SMR-17VO(FXO), SMR-17VF(VF) submodules. Maximum capacity is 8 interfaces (MR-17V8 used). Submodules may be installed in any combination.
Products:
Submodule SMR-17VO (2 pcs.)
Submodule SMR-17VF
Submodule SMR-17VO
Submodule SMR-17VS
Module MR-17Vo4 (4xFXO) with four FXO channels holds the “Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-.
