SG-17R/MR-17V8/4xSMR-17Vs (8xFXS, 4xETH 10/100) (CONFIGURATION EXAMPLE)
Typical assembly of 8-channel VoIP gateway with FXO, FXS and voice frequency channels.
The SG-17R base platform holds "Declaration of conformity" issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2554.
The MR-17Vo8 module with 8 FXO channels holds "Declaration of conformity" issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2566.
The MR-17Vs8 module with 8 FXS channels holds "Declaration of conformity" issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2569.
Products:
Module MR-17V8 (1 pc.)
Module MR-17G1
Module MR-17G2
Module MR-17G4
Module MR-17H1
Module MR-17H1P2
Module MR-17H2
Module MR-17S2C
Module MR-17S2T
Module MR-17S4C
Module MR-17V4
Module MR-17Vo8 (8xFXO)
Module MR-17Vs8 (8xFXS)
Submodule SMR-17VF
Submodule SMR-17VO
Submodule SMR-17VS
Module MR-17V8 1 order
1 order
4 order
Total order
