Sigrand:
telecommunication systems, IP CCTV systems, VoIP.
Cabinet
Home
Sign In
Русский
English
Main
News
Prices
About us
Contact us
Where to buy
Forum
Wiki
Alphabetical order
SG-17R/2xMR-17V/8xSMR-17Vs (16xFXS, 4xETH 10/100)
SG-17R/3xMR-17V/12xSMR-17Vs (24xFXS, 4xETH 10/100)
SG-17R/4xMR-17V/16xSMR-17Vs (32xFXS, 4xETH 10/100)
SG-17R/MR-17V/2*SMR-17Vs/MR-17G1 (4xFXS, 1xE1, 4xETH 10/100)
SG-17R/MR-17V/3xSMR-17Vs/MR-17H2/MR-17G1 (6xFXS, 2xSHDSL, 1xE1, 4xETH 10/100)
SG-17R/MR-17V/SMR-17Vs/MR-17H2 (2xFXS, 2xSHDSL, 4xETH 10/100)
SG-17R/MR-17V8/4xSMR-17Vs (8xFXS, 4xETH 10/100)
SG-17B SHDSL modem
SG-17BP SHDSL modem
SG-17BT SHDSL modem
SG-17R-1RU-CP1-4ETH/DC base platform
Module MR-17G1
Module MR-17G2
Module MR-17G4
Module MR-17H1
Module MR-17H1P2
Module MR-17H2
Module MR-17S4C
Submodule SMR-17VF
Submodule SMR-17VO
Submodule SMR-17VS
IP telephony
Families
SG-17 family
Modems
SG-17B SHDSL modem
SG-17BP SHDSL modem
Modules
Module MR-17G1
Module MR-17G2
Module MR-17G4
Module MR-17H1
Module MR-17H1P2
Module MR-17H2
Module MR-17S4C
Submodule SMR-17VF
Submodule SMR-17VO
Submodule SMR-17VS
Regenerators
Chassis
Video surveillance systems
IP-cameras
Data transmission systems
Routers
Modems
SG-17B SHDSL modem
SG-17BP SHDSL modem
Multiplexers
Regenerators
Terminal server
IP telephony
Linking telephones sets to PBXs using SHDSL
Establishing branched telephone business network using SHDSL, Ethenet, E1
Linking a group of Sigrand IP-cameras featuring SHDSL interfaces to the network over sigrand DSLAM
Linking a group of IP-cameras to the network over Sigrand commutator
Linking a group of IP-cameras featuring Ethernet and SHDSL interfaces to the network over Sigrand commutator
Linking a group of local and remote IP-cameras to the network over commutator
Branched linking of IP-cameras using Sigrand equipment
Linking remote Sigrand IP-cameras to the network over SHDSL
Linking remote Sigrand IP-camera featuring remote power supply over PoDSL through SHDSL link using regenerator
Linking remote arbitrary IP-camera with PoE-assisted remote power supply over SHDSL
Linking remote arbitrary IP-camera with PoE-assisted remote power supply over SHDSL using regenerator
Linking remote arbitrary IP-camera to the network using SHDSL
Uniting Ethernet networks using SHDSL with remote power supply over additional regenerator
Uniting Ethernet networks using SHDSL, up to 15.2 Mbit/s over single pair
Uniting Ethernet networks over E1 channel using SDH/PDH transport systems
Uniting Ethernet networks over several E1 channels using SDH/PDH transport systems
Uniting networks for "E1 + Ethernet" transmission over several pairs using SHDSL
Uniting networks for "E1 + Ethernet" transmission over single pair using SHDSL
Uniting networks for "E1 + Ethernet" transmission over E1 channel using SDH/PDH transport systems
Uniting networks using SHDSL with additional regenerators
Setting up standby or control channel over Dial-In server
Setting up terminal server using wireless technologies
Setting up terminal server using wire technologies
Setting up Internet gateway QoS provided
Transmitting data over RS232 interfaces using IP technology by means of different built-in channel-forming equipment
Transmitting voice frequency channels in the routing mode
Transmitting voice frequency channels for two- and four-wire terminations using SHDSL
Transmitting voice frequency channels over Ethernet, E1 and RS232 interfaces in multiplexing mode through E1 channels using SDH/PDH transport systems
Transmitting E1 streams using SHDSL
Transmitting E1 streams over Ethernet using IP and TDMoIP
Linking Ethernet network to provider through E1 interface using SHDSL over single pair
Linking Ethernet network to provider through E1 interfaces using SHDSL over several pairs
Linking users and networks to central access point for «Ethernet» and «E1 + Ethernet» mixed traffic transmission using SHDSL
Linking subscribers and networks to central access point using SHDSL
Linking subscribers and networks to central access point using wireless, optic or wire technologies
Linking equipment with serial interfaces to central access point in multiplexing mode over E1 channels using SHDSL
Systems of multiservice exchange between distributed objects using SHDSL on ring link
Systems collecting telemetric data from control objects
Setting up logically united channel that uses interface interdependence
IP telephony
Products in this and branch groups:
Typical assembly of 16-channel VoIP gateway with FXO, FXS or VF channels.
Typical assembly of 24-channel VoIP gateway with FXO, FXS and voice frequency channels.
Typical assembly of 32-channel VoIP gateway with FXS, FXO and voice frequency channels
Typical assemby of 2-channel VoIP gateway with FXO, FXS and voice frequency channels featuring additional E1 interface.
Typical assembly of 6-channel VoIP gateway featuring FXO, FXS or VF channels with additional SHDSL and E1 interfaces.
Typical assembly of 2-channel VoIP gateway with FXS, FXO and voice-frequency interfaces featuring additional SHDSL interface.
Typical assembly of 8-channel VoIP gateway with FXO, FXS and voice frequency channels.
