Linking telephones sets to PBXs using SHDSL
Purpose: setting up VoIP gateways with different functional FXO and FXS modules using DSL links. There is no need to install any extra telecommunication equipment because DSL interfaces may be installed directly in the VoIP gateway. It is possible to establish a connection through additional SG-17E regenerators with either local or remote power supply in order to link up super-remote clients. The line is powered from SHDSL module. From 2 to 32 single-type VoIP ports in increments of 2 may be installed simultaneously. There is an option of simultaneous operation of FXO, FXS and VF modules. There is also an option of voice traffic transfer over other interfaces of the basic SG-17R platform, namely Ethernet and E1.
Module MR-17H1, Submodule SMR-17VO, Submodule SMR-17VS, ( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform ), ( Module MR-17V4, Module MR-17V8 )
