Setting up terminal server using wireless technologies
Purpose: setting up terminal access server for console control of the remote equipment, linked to SG-17R over RS232 interfaces. Within this mode SG-17R is accessed remotely via wireless equipment, for example via GSM modems with further choice of the console port, to which the controlled device is linked. SG-17R may as well be accessed via modem for commute or dedicated lines. The control of SG-17R dial-in modes is carried out through built-in Dial-In server. If MR-17S* modules are used, it is possible to link up up to 15 devices featuring RS232 ports, apart from GSM modem. Along with linking up the equipment with serial channels any of the SG-17R interfaces may be used, for example to connect a local network, telephony or to link up voice frequency channel equipment. For establishing wireless IP-connections the SG-17R router may feature a built-in WiFi or WiMax module.
Module MR-17S2C,
Module MR-17S2T,
Module MR-17S4C,
