| SG-17BP SHDSL modemProduct designationSG-17BP SHDSL modem for traffic transmission between Ethernet and SHDSL interfaces. Receives remote power from information lineSections:Technical characteristics
Rate table
DescriptionSG-17BP SHDSL modem is considered to be the fastest among similar devices, the transfer rate reaching 15 296 kbit/s over single pair. The modem features an extended operating distance compared to that of g.shdsl.bis in the diapason under 5.7 Mbit/s. SG-17BP SHDSL modem is designed to unite distributed local networks, link up remote machines and Ethernet-featuring devices. The modem allows transmitting the VLAN IEEE 802.1Q tags either via SHDSL or Ethernet. SG-17BP SHDSL modem may be used both for connections in linking-up to central access units based either on SG-17AM, which functions as a 16 SHDSL ports DSLAM, or on SG-17R, which functions a router. Up to 6 SHDSL ports may be linked to a single SG-17R based on the SG-17R-1RU-CP1-4ETH platform. Up to 8 SHDSL ports may be linked to a single SG-17R based on the SG-17R-1RU-CP2-3SFP platform. MR-17H4P2 modules with 4 ports are used as SHDSL interfaces installed on SG-17AM base platform to ensure “remote power” mode. MR-17H1P2 and MR-17H2P2 modules with 1 and 2 ports are used for SG-17R base platform. When linked to SG-17AM or SG-17R the modem functions as Slave modem. Configuration of linear parameters of the Salve modem runs automatically in accordance to the Master settings. SG-17BP SHDSL modem enables reception of different parameters of the SHDSL channel via the EOC control channel. If the modem is linked to the SHDLS module of the SG-17R, installed on the base platform, complete automatic remote setting up of the connection line is possible. In this case the Master modem may be set up from any remote location, where network connection to SG-17R is available, and information on statistic gathering is available via SNMP, web-interface or console, installed of the base platform. SG-17BP SHDSL modem default kit features remote powering from 120-240 VDC information line from SG-17R base platform. Additional modifications with different powering:
Modem design:
Usage examplesUniting Ethernet networks using SHDSL with remote power supplyUsage example description Purpose: linking remote points (single computers or local Ethernet networks) over bridge link with shared addressing mode. Transfer rate over single pair reaches 15296 kbit/s. SG-17B allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces. The SG-17BP modem receives remote power from the line from SHDSL modules, installed on SG-17R or SG-17AM DSLAM. Using in usage example products and product groups SHDSL модем SG-17B-P-M,
SG-17BP SHDSL modem,
Module MR-17H1P2,
Module MR-17H2P2,
Uniting Ethernet networks using SHDSL with remote power supply over additional regeneratorUsage example description Purpose: linking remote points (single computers or local Ethernet networks) over bridge link with shared addressing mode. The link-up is completed through intermediate regenerator. Transfer rate reaches 14080 kbit/s over single pair. The SG-17BP modem allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces. The SG-17BP modem receives remote power from SG-17EP regenerator. The regenerator receives remote power from the line from SHDSL modules installed on 17R or SG-17AM DSLAM. Using in usage example products and product groups SG-17E2P-SLG,
Module MR-17H1P2,
Module MR-17H2P2,
Linking subscribers and networks to central access point using SHDSLUsage example description Purpose: linking remote points (single computers or local Ethernet networks) to the central network over bridge link with shared addressing mode or over internetwork connection with routing rules. Transfer rate over each pair reaches 14080 kbit/s. Up to 6 clients may be linked to a single SG-17R device based on the SG-17R-1RU-CP1-4ETH platform. Up to 8 clients may be linked to a single SG-17R device based on the SG-17R-1RU-CP2-3SFP platform. Up to 16 clients may be linked to a single SG-17R device in DSLAM mode. In order to link super-remote clients it is possible to use additional SG-17E regenerators with local or remote power supply. The line is powered over MR-17H*P SHDSL module. SG-17B or SG-17BP compact size modem may be used as a remote modem, having an option to receive remote power supply from information line. Using in usage example products and product groups SG-17B SHDSL modem,
Module MR-17H1P2,
Module MR-17H2,
View all usage examplesSoftwareWindows driver for setting up terminal when linked over USB: stmcdc.inf. Windows X64 driver for setting up terminal when linked over USB: vcpdriver_v1.1_setup.exe. DocumentsUser's guide is available here (PDF). CertificatesThe Sigrand SG-17B SHDSL modem holds the “Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on October 8, 2008, №DTS-2553 Price and warrantyWarranty5 yearsPrice
