Modular base platform 220 V AC power
  • Architecture of the SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform base platform
    • Ethernet 10/100
      Allows linking up various LAN resources without additional devices. All Ethernet ports are configured independently or operate in commutator mode. In case of commutator mode, all ports function as a single network interface and transmit data bypassing the processor.
      Ethernet interface characteristics:
      • Number of interfaces configured in LAN/WAN mode: 4
      • Global network protocols: PPPoE, PPTP
      • Interface type: 10/100 BaseT
      • Operation mode: half- and full-duplex
      • Compatibility: ANSI/IEEE Std 802.3
      • MDI/MDI-X automatic detection: available
    • RS232 console port
      Is used for router configuration.
      RS232 interface characteristics:
      • Protocol: 8-N-1
      • Stream management: not available
    • Number of extension modules: 4
    • Plug-in processor module support
      Makes it easier to choose processor module depending on the task with regard to such requirements as router performance, number of channels, encryption, etc.
      Processor module characteristics:
      • Processor type: ADM5120
      • Flash Memory, Mb: 32
      • SDRAM, Mb: 64
    • Power, V: 220 AC
    • Power consumption, W: 10
    • Size:
      • Height, mm: 44
      • Width, mm: 435
      • Depth, mm: 260
    • Material: metal
    • Environmental conditions:
      • Air temperature: 10 – 40 ºC
      • Relative air humidity: up to 85%
      • Air pressure: 84 – 107 kPa
  • Interfaces supported by SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform base platform:
    • SHDSL module
      Allows establishing remote connections in 2-, 4-, 6- and 8-wire mode.
      SHDSL interface characterisstics:
      • Number of ports depending on SHDSL module modification: 1, 2, 4 (without remote power supply)
      • Number of ports depending on SHDSL module modification: 1, 2 (240V remote power supply)
      • Number of ports depending on SHDSL module modification: 1, 2, 4 (120V remote power supply)
      • Maximum number of ports installed on SG-17R SG-17R: 6
      • Maximum number of ports installed on SG-17R SG-17R in DSLAM mode: 16
      • Connection type: point-to-point
      • Number of wires in a line depending on modification: 2 (one pair) 4 (two pairs), 8 (four pairs)
      • Transmission rate: 192-14080 кбит/c (over single pair)
      • Linear code: ТС-РАМ
      • Communication type: full duplex
      • Compatibility: SG-17B* modem, SG-17E* regenerator
    • E1 module
      Each of the E1 module interfaces may be used in the multiplexing into SHDSL, RS232 and other E1 channels mode. The interfaces may as well be used for data routing in HDLC mode.
      E1 interface characteristics:
      • Number of ports depending on module modification: 1, 2, 4, 8
      • Maximum number of ports installed on SG-17R:32
      • Number of wires in a line: 4 (2 pairs)
      • Linear code: (ITU-T G.703): HDB3, AMI
      • Transmission rate: Nx64 kbit/s
        N=1:32, for each E1 interface  (64:2048 kbit/s in increments of 64 kbit/s)
      • DTE distance, km: 2.4 (for 0.5 mm cable), 1.6 (for 0.4 mm cable)
      • Framing: G.704
      • Superframe: CRC4, CAS
      • Unframed mode: available
    • FXO/FXS module
      Features ports for linking up analog telephones with tone or impulse dialing for further transmission of voice using VoIP.
      FXO/FXS interfaces characterictics:
      • Number of ports: 2 on each submodule, up to 8 on one module
      • Maximum number of ports installed on SG-17R: 32
      • Hotline mode available
      • Option of changing of the transmitted frame, identificator codec in RTP-stream (payload)
      • Codec use and setup priority
      • Codecs supported: g711 (aLaw), g723, g729, g729e, g726 (на 16,24,32 и 40 kbps), iLbc (на 13.33 kbps)
      • Option on changing the bit packing order
      • Option of independent setup of the following characteristics for different channels: type of dtmf-signal transmission, volume during signal coding/decoding, activity detector, etc.
    • VF module
      Features ports linking up voice frequency channels for further transmission of the digitized signal using IP technology.
      VF interface characteristics:
      • Number of ports: 2 on one submodule, up to 8 on one module
      • Two- and four-wire mode supported
      • Transit mode: available
      • Call establishment without number dialing
      • Configuration options are similar to those of FXO/FXS modules
    • RS232 module
      Features ports for linking up equipment with serial interface.
    • Number of ports depending on modification: 2,4
    • Maximum number of ports installed on SG-17R: 16
    • Transmission rate: 300 to 230400 baud;
    • Data bits: 7 or 8 bits
    • Number of stop-bits: 1 or 2
    • Parity: ODD, EVEN, NONE
    • Control signals: DTR/DSR, RTS/CTS, CD, RI
  • Adapter-module for PCMCIA (CardBus) devices: Wi-Fi, etc.
    Ensures co-operation with wireless modules PCMCIA 802.11 a/b/g of different manufacturers in the frequencies including 2.4 GHz and 5 GHz. Enables the router to operate as access point or as client.  VLANs support is provided. An option of installation of different antennae is available.
    Wi-Fi interface characteristics:
    • Number of CardBus Card installed on single adapter-module: 1
    • Maximum number of CardBus Card installed on SG-17R: 3
    • The characteristics are determined by the type of CardBus Card installed
    • Requirements for CardBus Card: based on Atheros chipsets
Functions
The SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform modular platform is designed to operate as a router, multiplexer, bridge, DSLAM,  access server, IP-gateway, IT-PBX, most of the functions being carried out simultaneously by the same device.
  • BridgeThe bridge mode enables the device to carry out transparent traffic transmission between its interfaces. For example, it is possible to transmit traffic transparently between two Ethernet networks over an SHDSL consisting of several channels.
  • Multiplexer
    The multiplexer mode enables transmission of data streams by means of IP and TDM technologies, over the chosen broad-band interface (SHDSL, Ethernet, E1). Both E1 and RS232 interfaces may be used as narrow-band (low-speed) channels. In this case, additional router or bridge setup completed, the remaining band may be used for Ethernet traffic transmission. To transmit E1 streams over Ethernet by TDMoIP, SG-17R platform with a stronger processor module is used. Both copper medium 10/100/1000 Mbit/s and optical channel linked over plug-in SFP interface may be used as Ethernet.
  • Router
    The router mode enables transmission of traffic among different IP-networks, linked to different interfaces, routing rules observed. Both static and dynamic routing is supported.
  • DSLAM
    The DSLAM mode transforms SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform into commutator that transmits data between SHDSL or Ethernet network interfaces. The SHDSL and Ethernet modules, being parts of the device, are capable of power-feeding the link.
  • Access server
    The access server mode provides control over equipment linked to SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform over RS232.
  • IP-gateway
    The IP-gateway mode allows both separating and uniting telephones using VoIP and data transmission over Ethernet, SHDSL and E1.
IP-PBX
The IP-PBX mode allows setting up miniPBX, which, in its turn enables calls over SIP-server, calls between ports within single device or among different SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform devices. The miniPBX enables automatic call-forwarding between FXS/FXO ports.
Software:
The software of the SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform platform is Linux OS freeware. The platform is controlled through web-interface (Russian and English); troubleshooting is completed over serial port or over SSH protocol. The platform software is updated via TFTP server.
Data transmission
SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform supports “bonding” mechanism or PPP-Multilink protocol both of which enable uniting SHDSL, E1, RS232 interfaces for further increasing the carrying capacity and improving reliability. When using “bonding”, the channel capacity remains unchanged irrespective of integrity of the pairs, over which data is transmitted. Furthermore, transmission rate may be set taking into account the maximum carrying capacity of the channels.
SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform may operate as firewall, rejecting or accessing packets on the basis of the protocol, source and destination addresses and No. of the ports used. By means of NAT address translation applicable to SNAT or DNAT is completed.
QoS enables prioritizing packets. QoS is supported by various class and classless disciplines. There is an option of singling out fixed bands for different types of traffic or for different networks.
VLAN support helps to isolate traffic transmitted through the same physical medium. The port may be set up so as to transmit either entire traffic or single packets with certain LAN numbers.
SG-17R enables crating tunnels for tamper-free data exchange.
Hardware
Built-in Ethernet ports may be set up as commutators, i.e. may transmit data by-passing the processer. These ports operate as a single network interface in the system. Interdependence of the interfaces may be set, in which case, for instance, if the link on SHDSL fails, the link of the corresponding Ethernet or E1 interface turns down as well.
Services
SG-17R features built-in DHCP and DNS servers. DHCP server allows assigning IP addresses to PCs in the networks it runs in. DNS server helps transfer requests to higher-level DNS-servers or locate DNS zones directly on the device.
Monitoring
SG-17R enables receiving multiple parameters of SHDSL channel (signal to noise ratio, number of errors, etc) through separate EOC control channel. This information is available via web-interface or via SNMP (HDSL2-SHDSL-LINE-MIB).
Basic information on the system in accordance with MIB-2 is also available via SNMP: information about network interfaces, routing tables, processor load, etc.
Generation of NetFlow (v.1, 5, 7) may be set up for collection of statistic on the volume of traffic.
Purpose: splitting the users’ traffic in the shared physical medium of data transfer. The SG-17R device supporting VLAN technology allows uniting LAN 1 and LAN 2 networks independently. Up to 4 Ethernet networks may be simultaneously linked to a single SG-17R. Each Ethernet port may be set up so as to transfer either the whole traffic or single packets with a certain VLAN number. Transfer rate over each pair reaches 14080 kbit/s. Up to 6 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP1-4ETH platform. Up to 8 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP2-3SFP platform.
( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform ), ( Module MR-17H1, Module MR-17H1P2, Module MR-17H2, Module MR-17H2P2 )
Purpose: linking remote points (single computers or local Ethernet networks) over bridge link with shared addressing mode. Transfer rate over single pair reaches 15296 kbit/s. SG-17B allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces. The SG-17BP modem receives remote power from the line from SHDSL modules, installed on SG-17R or SG-17AM DSLAM.
SHDSL модем SG-17B-P-M, SG-17BP SHDSL modem, Module MR-17H1P2, Module MR-17H2P2, ( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform )
Module MR-17G1
Module MR-17G2
Module MR-17G4
Module MR-17H1
Module MR-17H1P2
Module MR-17H2
Module MR-17S2C
Module MR-17S2T
Module MR-17S4C
Module MR-17V4
Модуль MR-17Vo2 (2xFXO)
Module MR-17Vo2 (2xFXO)
Модуль MR-17Vo4 (4xFXO)
Module MR-17Vo4 (4xFXO)
Module MR-17Vo8 (8xFXO)
Модуль MR-17Vs2 (2xFXS)
Module MR-17Vs2 (2xFXS)
Модуль MR-17Vs4 (4xFXS)
Module MR-17Vs4 (4xFXS)
Module MR-17Vs8 (8xFXS)
The SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform base platform holds "Declaration of conformity", issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2554.
Total order
