SG-17 family
Branch groups in this and branch groups:
Products in this and branch groups:
SG-17E2P-SLG is designed for increasing the distance between two SHDSL devices SG-17E2P-SLG operates over 2 pairs. Each pair works idependently.
SG-17EP-SLG is designed for increasing the distance between two SHDSL devices SG-17EP-SLG operates over one pair
SHDSL модем SG-17B
SG-17B SHDSL modem
SG-17B SHDSL modem for traffic transmission between Ethernet and SHDSL interfaces.
SHDSL модем SG-17BP
SG-17BP SHDSL modem
SG-17BP SHDSL modem for traffic transmission between Ethernet and SHDSL interfaces. Receives remote power from information line
Modular base platform 220 V AC power
SG-17R-1RU-CP1-4ETH/DC base platform
Module MR-17G1
Module MR-17G2
Module MR-17G4
Module MR-17H1
Module MR-17H1P2
Module MR-17H2
Module MR-17S4C
Submodule SMR-17VF
Submodule SMR-17VO
Submodule SMR-17VS
