Module MR-17Vs2 (2xFXS)
Module MR-17Vs2 (2xFXS) (CONFIGURATION EXAMPLE)
 Module MR-17Vs2 (2xFXS) is a typical example of modular configuration. Module is designed for setting up analog interface for further linking to %%функциональность модуля%%. Module MR-17Vs2 (2xFXS) features %%количество интерфейсов%%; it includes one %%MR-17V%% module and %%число%% %%субмодуль%%.
 Module MR-17Vs2 (2xFXS) may be extended to maximum capacity with SMR-17VS(FXS), SMR-17VO(FXO), SMR-17VF(VF) submodules. Maximum capacity is 4 interfaces (MR-17V4 used), and 8 interfaces (MR-17V8 used). Submodules may be installed in any combination.
Products:
Submodule SMR-17VS (1 pc.)
Submodule SMR-17VF
Submodule SMR-17VO
Submodule SMR-17VS
 Module MR-17Vs2 (2xFXS) with 2 FXS channels holds the “Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2567.
