Module MR-17G1
Module MR-17G1
  • E1 interface parameters
    • Number of ports: %%количество портов на модуле%% RJ-45 Balanced
    • Number of wires per line: 4 (2 pairs)
    • Linear code  (ITU-T G.703): HDB3, AMI
    • Data transfer rate: Nx64 Kbit/sec, N=1:32, for each Е1 interface (64:2048 Kbit/sec with the pace 64 Kbit/sec)
    • Communication line length via E1, km: 2,4 (for 0.5 mm cable), 1.6 (for 0.4mm cable)
    • Cyclic structure (framing): G.704
    • Supercycle (superframe): CRC4, CAS
    • Switching off the cycle structure (unframed mode): available
    • Connector type: RJ-45 (socket)
  • System interface parameters
    •  Electric butting type: PCI
    • Bus-Master mode: available (for routing mode)
  • Operating modes
    • Data multiplexing  - TDM: available (for all E1 channels)
    • Data routing: available (%%количество портов для маршрутизации%% for all E1 channels)
    • Max number of modules installed  on  SG-17R-1RU-CP1-4ETH base platform in routing mode: 3
    • Max number of the modules installed on SG-17R-1RU-CP2-3SFP base platform in routing mode – TDM:  4
    • Max number of the modules installed on SG-17R* base platform in multiplexing mode – TDM: 4
  • Other characteristics
    • Module  size (with the lath):
      • height, mm: 20
      • width, mm: 164
      • depth, mm: 125
    • Weight, g: %%масса%%
    • Power consumption, W: %%потребление%%
  • Service conditions
    • Installed on SG-17R base platform
    • Air temperature: 10 – 40°С
    • Air pressure: 84 – 107 kPa
Uniting Ethernet networks over E1 channel using SDH/PDH transport systems
Purpose: uniting Ethernet networks through existing networks, built using E1 equipment. In order to increase the carrying capacity of SG-17R several E1/G.703 interfaces may be linked to the device. Single E1 module (MR-17G*) may feature up to 8 ports.
Module MR-17G1, ( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform )
 Purpose: splitting the users’ traffic in the shared physical medium of data transfer. The SG-17R device supporting VLAN technology allows uniting LAN 1 and LAN 2 networks independently. Up to 4 Ethernet networks may be simultaneously linked to a single SG-17R. Each Ethernet port may be set up so as to transfer either the whole traffic or single packets with a certain VLAN number. Single E1 module (MR-17G*) may feature up to 8 ports. Single SG-17R device may feature up to 32 E1 channels.
The Module MR-17G1 holds the “Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS 2556.
Total order
