Module MR-17H1
Module MR-17H1
  • G.SHDSL linear  interface parameters
    • Number of interfaces: %%количество портов на модуле%%
    • Link type: point-to-point
    • Number of wires per line: 2 (one pair)
    • Transfer rate, kbit/sec: 64 – 14080
    • Linear code: ТС-РАМ 192
    • Connection type: FDx
    • Compatibility: SG-17, SG-17+
  • System Interface parameters
    • Electric butting type: PCI
    • Bus-Master mode: available
    • Maximum number of modules installed on SG-17R-1RU-CP1-4ETH  base platform: 3
    • Maximum number of modules installed on SG- SG-17R-1RU-CP2-3SFP base platform: 4
  • Other characteristics
    • Module size (with the lath):
      • height, mm: 20
      • width, mm: 164
      • depth, mm: 125
    • Weight, g:
    • Power consumption, W: %%потребление%%
  • Service conditions
    • installed on the SG-17R base platform
    • Air temperature: 10 – 40°С
    • Air pressure: 84 – 107 kPa
  •  Remote power supply
    • remote power supply: not available
  • Service traffic
    • service traffic support: not available
Rate table
Rate, kbit/s0.5 mm cable, km0.9 mm cable, km (*)1.2 mm cable, km (*)
(*) - not all data obtained expermentally.
Purpose: splitting the users’ traffic in the shared physical medium of data transfer. The SG-17R device supporting VLAN technology allows uniting LAN 1 and LAN 2 networks independently. Up to 4 Ethernet networks may be simultaneously linked to a single SG-17R. Each Ethernet port may be set up so as to transfer either the whole traffic or single packets with a certain VLAN number. Transfer rate over each pair reaches 14080 kbit/s. Up to 6 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP1-4ETH platform. Up to 8 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP2-3SFP platform.
( SG-17R-1RU-CP1-4ETH/220VAC-W1 base platform, SG-17R-1RU-CP1-4ETH/DC base platform, SG-17R-1RU-CP2-3SFP/220VAC-W1 base platform ), ( Module MR-17H1, Module MR-17H1P2, Module MR-17H2, Module MR-17H2P2 )
The Module MR-17H1 holds the “Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2560.
Total order
