SG-17R/MR-17H2/MR-17G4 (2xSHDSL, 4xE1, 4xEth10/100) (CONFIGURATION EXAMPLE)
The SG-17R/MR-17H2/MR-17G4 (2xSHDSL, 4xE1, 4xEth10/100) multiplexer is designed for data streams transmission using IP and TDM technologies over dedicated metallic circuits.
  • Supported control modes: Web, SSH, CLI, SNMP
  • Ethernet 10/100
    Allows linking up various LAN resources without additional devices. All Ethernet ports are configured independently or operate in commutator mode. In case of commutator mode, all ports function as a single network interface and transmit data bypassing the processor.
    Ethernet interface characteristics
    • Number of interfaces configured in LAN/WAN mode: 4
    • Global network protocols: PPPoE, PPTP
    • Interface type: 10/100 BaseT
    • Operation mode: half- and full-duplex
    • Compatibility: ANSI/IEEE Std 802.3
    • MDI/MDI-X automatic detection: available
  • RS232 console port
    Is used for router configuration.
    RS232 interface characteristics
    • Protocol: 8-N-1
    • Stream management: not available
  • Number of extension modules: 4
  • Plug-in processor module support
    Makes it easier to choose processor module depending on the task with regard to such requirements as router performance, number of channels, encryption, etc.
    Processor module characteristics:
    • Processor type: ADM5120
    • Flash Memory, Mb: 32
    • SDRAM, Mb: 64
  • Power, V: 220 AC
  • Power consumption, W: 10
  • Size:
    • Height, mm: 44
    • Width, mm: 435
    • Depth, mm: 260
  • Material: metal
  • Environmental conditions:
    • Air temperature: 10 – 40 ºC
    • Relative air humidity: up to 85%
    • Air pressure: 84 – 107 kPa
Extension modules for SG-17R/MR-17H2/MR-17G4 (2xSHDSL, 4xE1, 4xEth10/100) configuration:
  • %%тип модуля SHDSL%% SHDSL module
    Used for establishing remote connections in the two- %%режим работы SHDSL%%wire mode.
    SHDSL interface characteristics:
    • Number of interfaces: %%количество интерфейсов SHDSL%%
    • Maximum number of interfaces installed on SG-17R in combination with other module types: 6
    • Connection type: point-to-point
    • Number of wires in a line per each interface: 2 (one pair)
    • Transmission rate: 192-14080 kbit/s over single pair
    • Linear code: TC-PAM
    • Communication type: full duplex
    • Compatibility: SG-17B* modem, SG-17E* regenerator
  • %%тип модуля E1%% E1 module
    Each of the E1 module interfaces may be used in the multiplexing into SHDSL, RS232 and other E1 channels mode. The interfaces may as well be used for data routing in HDLC mode.
    E1 interface characteristics:
    • Number of interfaces: %%количество интерфейсов E1%%
    • Maximum number of interfaces installed on SG-17R in combination with other module types: 24 (MR-17G8 used)
    • Number of wires in a line: 4 (2 pairs)
    • Linear code: (ITU-T G.703): HDB3, AMI
    • Transmission rate: Nx64 kbit/s
      N=1:32, for each E1 interface  (64:2048 kbit/s in increments of 64 kbit/s)
    • DTE distance, km: 2.4 (for 0.5 mm cable), 1.6 (for 0.4 mm cable)
    • Framing: G.704
    • Superframe: CRC4, CAS
    • Unframed mode: available
Rate table
Rate, kbit/s0.5 mm cable, km0.9 mm cable, km (*)1.2 mm cable, km (*)
(*) - not all data obtained expermentally.
The SG-17R/MR-17H2/MR-17G4 (2xSHDSL, 4xE1, 4xEth10/100) multiplexer is designed in a 1U height compact case for 19’’ rack-mount drawer. The multiplexer features 4 Ethernet 10/100 ports, %%количество интерфейсов%%. %%наличие резервного порта%%
The data from IP channel is transmitted through Ethernet interface, while TDM stream uses E1 port, capable of transmitting both full-size and divided streams.
The administration of SG-17R/MR-17H2/MR-17G4 (2xSHDSL, 4xE1, 4xEth10/100) may be competed through serial interface, SNMP, Web, ssh. The device features options of remote program update, configuration saving and restoring.
The SG-17R/MR-17H2/MR-17G4 (2xSHDSL, 4xE1, 4xEth10/100) multiplexer may be used both in business and carrier networks. In the first case, up to 30 telephone channels may be linked to the corporate information structure over E1 stream; the company’s branch LAN may be linked up over Ethernet interfaces. Network carriers, on the other hand, may use networks built on different technologies (TDM and IP) link up to primary providers and to setting up private DTNs.
The SG-17R/MR-17H2/MR-17G4 (2xSHDSL, 4xE1, 4xEth10/100) multiplexer features plug-in modular architecture. By means of a built-in 4-port Ethernet 10/100 commutator it is possible to unite a small local group, with the possibility for each of the ports to be configured individually according to the traffic-control rules. Each of the ports may as well function as a LAN or WAN interface. Port-based and port-tagged VLAN is supported.
The SG-17R-1RU-CP2-3SFP/220VAC-W1 variant of the base platform may be used to link to high-speed gigabit trunks.
Installation of several multi-channel SHDSL modules on SG-17R/MR-17H2/MR-17G4 (2xSHDSL, 4xE1, 4xEth10/100) allows transmitting data over 6 pairs, which helps to increase the rate between two points or to arrange E1+Ethernet multiplexing in different directions. The maximum rate in the line reaches 14080kbit/s over single pair. This allows transmitting up to 6 E1 streams over single pair. In the multiplexing mode, multi-pair link used, the E1 streams’ surpluses are aggregated in a single logical link for Ethernet transportation. The “remote power supplier” mode allows using these devices together with SG-17E regenerators. This allows setting up rate-maintaining DTCs and increasing the distance between SHDSL devices. The SG-17R/MR-17H2/MR-17G4 (2xSHDSL, 4xE1, 4xEth10/100) multiplexer features built-in option of circuit monitoring in accordance with the G.991.2 standard. The multiplexer supports MIB-II and HDSL2-SHDSL-LINE-MIB.
If needed, the SG-17R/MR-17H2/MR-17G4 (2xSHDSL, 4xE1, 4xEth10/100) equipment may simultaneously be a multiplexer and a router for different interfaces.
When used as a router, DHCP and DNS settings may be used; traffic management is carried out by means of NAT, Firewall, QoS. The device allows using static paths and itself may be using RIP protocol. If there is no need and the router-mode is off, the device may function as a bridge in the mode of direct-connection between the chosen interfaces.
Additional FXO/FXS/VF telephone modules allow linking up subscriber lines form BPXs, telephones, fax machines and voice-frequency channels equipment. The SG-17R base platform allows installing all these modules in different combinations.
Additional modules featuring RS-232 interface allow linking different equipment with COM ports which enables: remote control over different devices, data collection form sensors and controllers, setting up main and standby channels using subsidiary wireless modems or modems for dedicated metallic circuits and commutated lines.
Adapter-module for CardBus Card allows using standard devices of this class, for example, to establish a Wi-Fi connection. In this case the device may be either access point or the client.
For additional services there are two modes available in the standby SHDSL band:  data-multiplexing mode and packet-mode with isolated fixed pass-band and QoS for the requested service.
Uniting networks for "E1 + Ethernet" transmission over several pairs using SHDSL
Purpose: simultaneous IP and TDM transfer of mixed traffic over DSL links. As the transfer rate over single pair may reach 14080 kbit/s, up to 6 E1/G.703 ports may be linked to a single SG-17R for single-pair transfer. Up to 3 E1 modules may be installed, only one DSL module used.  One E1 module (MR-17G*) may feature up to 8 ports. Single SG-17R device may feature up to 6 pairs. There is an option to aggregate the surplus of the Ethernet bands from different pairs into a single logical channel. Another option is to arrange traffic isolation among networks by means of VLAN.
Linking Ethernet network to provider through E1 interfaces using SHDSL over several pairs
Подключение Ethernet сети к провайдеру через интерфейсы E1 с использованием  SHDSL технологии по нескольким парам
Purpose: linking Ethernet networks to providers who render the services by means of G.703/E1 ports. As the transfer rate over single pair reaches 14080 kbit/s, up to 6 E1 ports may be linked to SG-17R for single-pair transfer. In case of large distance, the E1 flow may be transferred over several pairs. Up to 6 pairs may be linked to a single SG-17R device, E1 module used. Single E1 module (MR-17G*) may feature up to 8 ports. One SG-17R device functions in the router mode, the other – in the bridge mode or router mode. The PPP-Multilink protocol is used to guarantee compatibility with other devices over E1. Other interfaces of SG-17R may be used as channel-forming equipment for E1 transfer, namely Ethernet and E1.
Products:
Module MR-17G4 (1 pc.)
Module MR-17G1
Module MR-17G2
Module MR-17G4
Module MR-17H1
Module MR-17H1P2
Module MR-17H2
Module MR-17S2C
Module MR-17S2T
Module MR-17S4C
Module MR-17V4
Module MR-17Vo8 (8xFXO)
Module MR-17Vs8 (8xFXS)
The SG-17R base platform holds "Declaration of conformity" issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2554.
The MR-17H2 module holds "Declaration of conformity" issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2562.
Module MR-17G4 1 order
1 order
1 order
Total order
