Purpose: uniting two Ethernet networks to reach full output in the link by using the bonding mode. In this scheme SG-17R provides either internetwork connection between two Ethernet groups with routing rules or bridge link with shared addressing of the networks united. Transfer rate over each pair reaches 14080 kbit/s. Different transfer rate may be set up in different pairs. It is important that even if on one of the pairs there is a link loss, the performance of the channel does not fail. Up to 6 pairs may be simultaneously linked to a single SG-17R device for SHDSL links based on SG-17R-1RU-CP1-4ETH platform. Up to 8 pairs may be simultaneously linked to a single SG-17R device for SHDSL links based on SG-17R-1RU-CP2-3SFP platform. Besides, in the bonding mode it is possible to unite any kind of channel-forming equipment, through which IP-traffic is transferred: E1, RS-232. Both Ether-HDLC and PPP-multilink may be chosen as protocols.
Module MR-17G1,
Module MR-17G2,
Module MR-17G4,
Module MR-17H1P2,
Module MR-17H2,
Module MR-17S2C,
Module MR-17S2T,
Module MR-17S4C,
Purpose: splitting the users’ traffic in the shared physical medium of data transfer. The SG-17R device supporting VLAN technology allows uniting LAN 1 and LAN 2 networks independently. Up to 4 Ethernet networks may be simultaneously linked to a single SG-17R. Each Ethernet port may be set up so as to transfer either the whole traffic or single packets with a certain VLAN number. Transfer rate over each pair reaches 14080 kbit/s. Up to 6 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP1-4ETH platform. Up to 8 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP2-3SFP platform.
Module MR-17H1P2,
Module MR-17H2,
Purpose: linking remote points (single computers or local Ethernet networks) over bridge link with shared addressing mode. Transfer rate over single pair reaches 15296 kbit/s. SG-17B allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces. The SG-17BP modem receives remote power from the line from SHDSL modules, installed on SG-17R or SG-17AM DSLAM.
SHDSL модем SG-17B-P-M,
SG-17BP SHDSL modem,
Module MR-17H1P2,
Module MR-17H2P2,
Uniting Ethernet networks using SHDSL with remote power supply over additional regenerator
Purpose: linking remote points (single computers or local Ethernet networks) over bridge link with shared addressing mode. The link-up is completed through intermediate regenerator. Transfer rate reaches 14080 kbit/s over single pair. The SG-17BP modem allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces. The SG-17BP modem receives remote power from SG-17EP regenerator. The regenerator receives remote power from the line from SHDSL modules installed on 17R or SG-17AM DSLAM.
SG-17E2P-SLG,
Module MR-17H1P2,
Module MR-17H2P2,
Uniting Ethernet networks over E1 channel using SDH/PDH transport systems
Purpose: uniting Ethernet networks through existing networks, built using E1 equipment. In order to increase the carrying capacity of SG-17R several E1/G.703 interfaces may be linked to the device. Single E1 module (MR-17G*) may feature up to 8 ports.
Module MR-17G1,
Purpose: splitting the users’ traffic in the shared physical medium of data transfer. The SG-17R device supporting VLAN technology allows uniting LAN 1 and LAN 2 networks independently. Up to 4 Ethernet networks may be simultaneously linked to a single SG-17R. Each Ethernet port may be set up so as to transfer either the whole traffic or single packets with a certain VLAN number. Single E1 module (MR-17G*) may feature up to 8 ports. Single SG-17R device may feature up to 32 E1 channels.
Module MR-17G1,
Module MR-17G2,
Module MR-17G4,
Uniting Ethernet networks over several E1 channels using SDH/PDH transport systems
Purpose: uniting Ethernet networks through existing networks, built using E1 equipment. In order to increase the carrying capacity of SG-17R several E1/G.703 interfaces may be linked to the device. Single E1 module (MR-17G*) may feature up to 8 ports. Up to 32 E1 channels may be simultaneously linked to single SG-17R.
Module MR-17G1,
Module MR-17V4,
Submodule SMR-17VF,
Submodule SMR-17VO,
Submodule SMR-17VS
Uniting networks for "E1 + Ethernet" transmission over several pairs using SHDSL
Purpose: simultaneous IP and TDM transfer of mixed traffic over DSL links. As the transfer rate over single pair may reach 14080 kbit/s, up to 6 E1/G.703 ports may be linked to a single SG-17R for single-pair transfer. Up to 3 E1 modules may be installed, only one DSL module used. One E1 module (MR-17G*) may feature up to 8 ports. Single SG-17R device may feature up to 6 pairs. There is an option to aggregate the surplus of the Ethernet bands from different pairs into a single logical channel. Another option is to arrange traffic isolation among networks by means of VLAN.
Module MR-17G1,
Module MR-17G2,
Module MR-17G4,
Module MR-17H1P2,
Module MR-17H2,
Uniting networks for "E1 + Ethernet" transmission over single pair using SHDSL
Purpose: simultaneous IP and TDM transfer of mixed traffic over DSL links. As the transfer rate over single pair may reach 14080 kbit/s, up to 6 E1 ports may be linked to SG-17R for single-pair transfer. Single E1 module (MR-17G*) may feature up to 8 ports. Up to 6 pairs may be simultaneously linked to a single SG-17R.
Module MR-17G1,
1 - 10
11 - 20
21 - 30
31 - 40
41 - 50
