Data transmission systems
Branch groups in this and branch groups:
Products in this and branch groups:
SG-17E2P-SLG is designed for increasing the distance between two SHDSL devices
SG-17E2P-SLG operates over 2 pairs. Each pair works idependently.
SG-17EP-SLG is designed for increasing the distance between two SHDSL devices
SG-17EP-SLG operates over one pair
The SG-17R/2xMR-17H2/2xMR-17G8 (4xSHDSL, 16xE1, 4xEth10/100) multiplexer is designed for data streams transmission using IP and TDM technologies over dedicated metallic circuits.
SG-17R/2xMR-17H2/2xMR-17G8 (4xSHDSL, 16xE1, 4xEth10/100) allows transmirring up to 16 E1 and Ethernet streams over 3 pairs.
The SG-17R/2xMR-17H2/MR-17G4 (4xSHDSL, 4xE1, 4xEth10/100) multiplexer is designed for data streams transmission using IP and TDM technologies over dedicated metallic circuits.
SG-17R/2xMR-17H2/MR-17G4 (4xSHDSL, 4xE1, 4xEth10/100) allows transmitting up to 4 E1 and Ethernet streams over 1 to 4 pairs.
SG-17R/2xMR-17S4T (8xRS232, 4xEth10/100) terminal server is used for console control over remote equipment. The SG-17R/2xMR-17S4T (8xRS232, 4xEth10/100) terminal server allows linking up to 8 devices to RS232 interfaces. The terminal server is accessed over Ethernet interface
SG-17R/3xMR-17S4T/MR-17H1 (12xRS232, 1xSHDSL, 4xEth10/100) terminal server is used for console control over remote equipment. The SG-17R/3xMR-17S4T/MR-17H1 (12xRS232, 1xSHDSL, 4xEth10/100) terminal server allows linking up to 12 devices to RS232 interfaces. The terminal server is accessed over SHDSL or Ethernet interfaces.
SG-17R/4xMR-17S4T (16xRS232, 4xEth10/100) terminal server is used for console control over remote equipment. The SG-17R/4xMR-17S4T (16xRS232, 4xEth10/100) terminal server allows linking up to 16 devices to RS232 interfaces. The terminal server is accessed over Ethernet interface.
SG-17B SHDSL modem
SG-17B SHDSL modem for traffic transmission between Ethernet and SHDSL interfaces.
SG-17BP SHDSL modem
SG-17BP SHDSL modem for traffic transmission between Ethernet and SHDSL interfaces.
Receives remote power from information line
