Submodule SMR-17VO
- SMR-17VO general characteristics:
- Number of FXO channels on one submodule: 2
- Connector type: RJ-11
- Battery voltage, V: 30 – 72
- Call voltage amplitude, V: 30 – 120
- Call signal frequency, Hz: 15 - 65
- Two-wire termination impedance, Ω: 600
- System interface parameters
- Electrical joint type: 40+10 contacts, proprietary
- Max number of submodules installed on one MR-17V motherboard: 4
- Operation mode:
- Data multiplexing – TDM: available
- Data routing: available
- Max number of submodules installed on one SG-17R*: 16
- Codecs:
- High quality: G711 (A-law)
- High speed: G729
- Full VoIP codec stack support option
- Other characteristics
- Module size (with the lath):
- Height, mm: 9
- Width, mm: 32
- Depth, mm: 98
- Weight, g:
- Power consumption, W: 0,6
- Service conditions
- On the SG-17R tub together with MR-17V module
- Air temperature: 10 – 40 °С
- Relative air humidity: up to 85%
- Air pressure: 84 – 107 кПа
Submodule SMR-17VO features 2 FXO interfaces (foreign exchange office) for linking up subscriber lines from PBXs. Interface of this type provides the following services: - answer signal
- dialing
- disconnect signal
Submodule SMR-17VO transmits data using IP-technology. The equipment transforms analog data into digital and forms packets to be sent over IP-network, which provides the following options, when used within SG-17R base platform: - Using existing IP-networks for data transmission
- Setting up multipurpose traffic within the chosen data channel
- Managing traffic within the chosen transmission channel, both using QoS and dedicating a fixed band for IP-traffic
- Transmitting data through heterogeneous media, like optics, EM waves, satellite signals, which require data routing at junctions
Transmitting data over various interfaces (Ethernet, SHDSL, E1, RS232) without additional equipment. Submodule SMR-17VO may operate installed on the SG-17R base platform, combined with other submodules, namely SMR-17VO (FXO), SMR-17VS (FXS), installed on the same or different MR-17V* module-boards. Software for VoIP modules based on SG-17R base platform: - Setting up operation modes for VoIP-modules over web-interface
- Codecs: g711 (aLaw and uLaw) – 64 kbit/s, g723 – 6,4 kbit/s, g729 – 8 kbit/s, g729e, g726 (at 16,24,32 and 40 kbit/s), iLbc (at 13.33 kbit/s)
- T.38 support (for facsimile messages)
- Alteration of transmission-frame, codec identificator in the rtp-stream (payload) and the order of bit-packing (aal2 or rtp) for g726.
- Prioritization of codecs
- Independent setup for such channel characteristics as: dtmf transmission type (in-band, out-of-band (rfc2833), both or none), payload when using rfc 2833, volume when signal coding/decoding, activity sensor (VAD), HPF (high-pass filter)
- Determining sip-uri and the registration server for linkup to a remote sip-address during operation time (the coming calls will be redirected to the chosen FXS channel)
- “Hotline” option (for FXS channel it means that the call we directed to the chosen address the second the telephone handset is lifted; for FXO channel it will mean redirecting the call from PBX)
- Telephone book
Usage example description Purpose: setting up VoIP gateways with different functional FXO and FXS modules. From 2 to 32 single-type ports in increments of 2 may be installed simultaneously. Simultaneous operation of the FXO (MR-17V8/SMR-17Vo) and FXS (MR-17V8/SMR-17Vs) modules is possible, the modules possessing the functions of a mini-BPX. Any interfaces of SG-17R (Ethernet, SHDSL, E1) may operate as channel-forming equipment.
Using in usage example products and product groups Module MR-17G1,
Module MR-17V4,
Submodule SMR-17VF,
Submodule SMR-17VO,
Submodule SMR-17VS
Using in usage example products and product groups SHDSL модем SG-17B-3.3-M,
Module MR-17V8,
Submodule SMR-17VO,
Submodule SMR-17VS,
Usage example description Purpose: simultaneous transfer of voice frequency channels and other services, e.g. Ethernet or VoIP-based telephony. VF channels may be transmitted with a fixed band being isolated in the global traffic that is transmitted through existing city infrastructure, e.g. SDH network.
Module MR-17V4,
Submodule SMR-17VF,
Submodule SMR-17VO,
Submodule SMR-17VS
Module MR-17V4
Submodule SMR-17VO with two FXO channels holds the “Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2567. Submodule SMR-17VO with four FXO channels holds the “ Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2568. Submodule SMR-17VO with eight FXO channels holds the “Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2569.
years
Product name |
Quantity (pc.) |
Price in USD |
Price in FOB USD:
Total |
order
