Systems of multiservice exchange between distributed objects using SHDSL on ring link
Purpose: setting up multiservice data exchange between distributed objects; organizing data transfer to data collection centre. On SG-17R routers both linear and ring links may be established. SHDSL interface with additional regenerators is used as channel-forming equipment. Up to 8 regenerators with operation rate up to 14080 kbit/s may be installed on each section. Circuit caching may be completed with several pairs. Additional use of OSFP dynamic routing allows reversing the transmission, should direct transmission fail. SNMP support establishes central control of the whole DTS.
